by djaykay Investigator
Firmware for HH70VB (4GEE Wifi home router had a bad flash)
I did a firmware update the other night and it killed the router. I'm fairly technical so I hooked it up to my computer and I can get into the OpenWrt busybox via telnet, and can see that it's in a bad way but is obviously working at its most basic level after a bad firmware flash.
I don't want to send this to landfill when it doesn't need much to get it back up and running. Bad for the planet for one.
Could someone send me a firmware that I can flash with OpenWrt's "sysupgrade" tool?
Thanks!
9 REPLIES 9
Re: Firmware for HH70VB (4GEE Wifi home router had a bad flash)
Hi @djaykay
Welcome to the community.
Could you try factory resetting your router please?
Let us know if it's any better after that.
Hey Christopher,
I did – it doesn't do anything.
When I turn it on, only the wifi light comes on for about 2-3 seconds then goes off. It then stays dark but like I say, I can connect via telnet.
If I can get a firmware file to flash via telnet/tftp then I can probably resurrect it.
Cheers!
Thanks for trying that, @djaykay.
I recommend speaking to technical support
Hopefully, they'll be able to help you more with that.
Hey Chris,
I have done and they said they'd send a new one out and to bin the other one which is hugely wasteful given that it can be fixed as I have the skills to do it but not the resource I need.
Cheers
That's modern repair theory for you.
EE may have the resource but not the skills to do it Smiley Wink!
by geoffers12 Investigator
More than likely, they don't want to give out the firmware incase people spot that they've got hard-coded credentials in them.
https://www.theregister.co.uk/2018/10/26/ee_4gee_hh70_ssh_backdoor/
by stephen171
Hello, i read your post and am having a similar issue presently. Hoe were you able to resolve this issue.
Regards
Unfortunately as no one would assist (EE or Alcatel) I ended up taking it to the recycling centre.
