by Gunda4
New Member
EEmini wifi
How do you reset the password on the EE WiFi Mini please.
Solution
Re: EEmini wifi
@Gunda4 : Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. You can find the WiFi pwd in clear & change it under the WiFi Settings tab.
Solution
Re: EEmini wifi
