by Alexhill
EE 4G home router does not work with Amazon Fire Tv
After 1hrs and 3 phone calls to EE a second line technical person announces EE 4G service does not work with Amazon Fire TV due to being an IPV6 service! This is really poor of EE to give up on a customer, saying it just won’t work... they must know why... I’ve contacted Amazon I await any support they can give EE doesn’t care.
Re: EE 4G home router does not work with Amazon Fire Tv
Can't you switch the router to a IPv4 profile?
by LesleyF Investigator
I have same problem, I've wasted most of today trying to sort it out!!!
Hi @LesleyF
I can see you are in discussion here about this.
Richard
by BobbyC101st
I have a solution:- This setting will allow connection to Amazon Fire which is IPV4 only.
in the router settings, select data type then select IPv4 then you will be asked to disconnect, say yes, save as IPV4 then re-connect and exit router.
I use both IpV4/6 setting after selecting IPV6, disconnect, save then select IPV4/6 and save, reconnect.
I now have both IPV4 and IPV6 depending on the website visited.
Confirmed by checking on this link:- http://test-ipv6.com/index.html.en_US
my status is:-
Test with IPv4 DNS record
ok (0.144s) using ipv4
Test with IPv6 DNS record
ok (0.144s) using ipv6
Test with Dual Stack DNS record
ok (0.153s) using ipv6
Test for Dual Stack DNS and large packet
ok (0.100s) using ipv6
Test IPv4 without DNS
ok (0.117s) using ipv4
Test IPv6 without DNS
ok (0.112s) using ipv6
Test IPv6 large packet
ok (0.166s) using ipv6
Test if your ISP's DNS server uses IPv6
ok (0.170s) using ipv6
Find IPv4 Service Provider
ok (0.324s) using ipv4 ASN 12576
Find IPv6 Service Provider
ok (0.288s) using ipv6 ASN 12576
