by Tomaplin1
EE 4G Mobile Wifi Mini Stuck Sim Card
Hello,
I have accidentall stuck a SIM card into the port of my 4GEE mini device, could you recommend some actions i can take to remove this?
Thanks,
Tom
Solution
Re: EE 4G Mobile Wifi Mini Stuck Sim Card
Hi @Tomaplin1.
Welcome to the community.
If this is not easily removed we don't want you to force it and potentially cause damage to your device.
Do you have a local store near you? You are more than welcome to pop in and one of the team will be happy to look at this for you.
Katie 🙂
Solution
Hi @Tomaplin1.
Katie 🙂
by Tomaplin1
OK good thinking, thank you.
Get Outlook for Android
