by Rob_Bramley Investigator
EE 4G Antenna
I currently have a 4GEE Mobile Router  and am getting the signal strength switching between 1 and 2 bars of strength.
Can you advise if I am eligible for a Antenna installation as my signal strength isn't the greatest.
Solution
Re: EE 4G Antenna
You could buy a compatible aerial if you like.
7 REPLIES 7
Re: EE 4G Antenna
Yes, if the 1 you have is the 4GEE HOME ROUTER . It is not free but £100.
Re: EE 4G Antenna
This is the router I have.
https://images.app.goo.gl/prbqUtymse7qXYCw9
Re: EE 4G Antenna
That's it!
Re: EE 4G Antenna
Do I just ring Ee?
Re: EE 4G Antenna
Yes, it's all on that page I gave you.
Re: EE 4G Antenna
Does it need to be an EE specific antenna or can you buy a 3rd party and install to the router?
Solution
Re: EE 4G Antenna
Recent solutions
