Highlighted
by Investigator
Data Usage - 4GEE wifi mini
Is there any way of seeing how much data is being used at a particular time?
Either in real time or in the past.
For Example can I log in anywhere so it tells me how much data is being consumed at that particular time?
Or can I log in somewhere and see a list of say, daily usage?
We run seven work clubs and 2 of them use the 4GEE wifi mini, but as the clients are only job searching and sending emails, we seem to be using a fair amount of data.
The work clubs are on fortnightly for 2 hours at a time and we have from 2 to 6 people searching the net at one time.
Using the data from a page I found searching for an answer, about 2mb per minute internet, so we should have used around 2gb, but we've used 6gb.
I need to try and track down which work club we have problems with, maybe someone using youtube or something, or the workers are allowing the laptops to update when connected.
Highlighted
Solution
Re: Data Usage - 4GEE wifi mini
Hi @SSWC.
This isn't possible to do through EE, you can only check how much data you have left.
You may be able to find an app that supports this, if not then it won't be possible.
Jon
Highlighted
Hi @SSWC.
Welcome to the community.
Are you keeping an eye on your usage in your My EE Account?
It's not possible to check how much data is being used in real time, unless there's an app out there for this type of thing.
Jon
Highlighted
by Investigator
I can see how much we have left ok, and I can see what's been used day by
day, I'd rather like to see something a bit more accurate, rather than by
the GB.
Graham
South Staffs Work Clubs
http://southstaffsworkclubs.btck.co.uk/OurWorkClubs
Highlighted
Solution
Hi @SSWC.
Jon
Highlighted
by Investigator
Thanks, I guessed that was the case, I'll use other methods and look for an app that  might do it.
Graham
