by devpete
Changing password
I have installed a 4GEE router and want to change the password and access the settings. The front page says "Change your 4GEE WiFi device SSID password. Log In". If I click on the link it takes me to the screen where I am asked to enter my administrator password, which I presume is the WiFi Key as per the label on the device. If I enter that I get the message Incorrect Password. I have tried multiple times and even reset the device using the reset button on the side. But every time I get the same Incorrect Password message. Any ideas?
Solution
Re: Changing password
The admin pwd & the WiFi pwd are not the same thing. Try "admin" if the admin pwd is not also on the label.
Solution
Hi @devpete
Welcome to the community. 🙂
Did typing 'admin' as the password work? Otherwise, as @XRaySpeX said, the admin password should be on the label.
Let us know how you're getting on.
by devpete
Thanks XRaySpeX and Christpher. No the admin password is nowhere on any documentation or cable in my box. Your suggestion worked perfectly and then I could access the User Manual which tells me that admin is the password ...... but of course I couldn't access that section of the menu until I had entered admin initially! Doh! EE could make life a little simpler for us mortals couldn't they?
But thanks guys - you solved my problem.
Thanks for letting us know that worked @devpete 🙂
I've marked this thread as solved.
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
Recent solutions
