by Newbe82 Contributor
Changing from EE home WiFi to EE fibre
Would I be able just to change over without having to pay any existing months payments
Solution
Re: Changing from EE home WiFi to EE fibre
Hello there @Newbe82
If you give us a call on either 150 or 0800 079 8586, we will be able to look at cancelling your existing mobile broadband and setting you up with fibre broadband.
The team will be able to check any cancellation costs and let you know your next steps.
Thanks, Leanne 🙂
No, EE mobile products are entirely separate from Home BB & there is no upgrade path between them.
Solution
Thanks, Leanne 🙂
Thank you all sorted and changed over,much appreciated
No problem @Newbe82 Smiley Happy
I'm glad you were able to find the help you needed in the community.
