by timrob39
Change osprey to home box
I'm wanting to change my osprey to the home broadband box to allow me to connect more devices and keep it switched on all the time (the battery on my osprey isn't too good now it's been plugged in 24/7 for some time). I don't want to change the contract as I'm not quite half way through and don't wish to pay the cancellation fee.
Can I pay for the device and just switch the simple card over? How would I go about this?
Thanks in advanced,
Tim
by Profile closed
Not applicable
Solution
Re: Change osprey to home box
Hello @timrob39 you would have to buy the PAYG version of the 4GEE Home Router with a preloaded PAYG SIM but you can put any EE, T-Mobile or Orange SIM in once you have received it. The 4GEE Home Router uses the micro(middle) sized SIM cards. 🙂
Yes, just switch the SIM. They are probably the same size, nano SIMs.
by Profile closed
Not applicable
Solution
