by Caity1991 Investigator
Cannot activate new sim because not using in a phone
I have recently ordered a replacement SIM for an Osprey 2 Mini device. I cannot activate the new SIM because it's a 4Gee only device, not a mobile phone, so I cannot receive the text message with the authentication code. And the SIM must be the micro size, which won't fit in my phone to get the code! What can I do?
7 REPLIES 7
Re: Cannot activate new sim because not using in a phone but It Does SMS!
Yes, you can! The Osprey 2 Mini does SMS as do most MBB routers. It even has a light showing you there are unread 1s.
by Ace Contributor
@Caity1991
try THIS it will explain how you can log into your device to read the text message.
alternatively call 0800 956 3146 from 8AM and it will get you straight through to a tech advisor.
@Caity1991  Have a look at THIS it will explain how you can logon to the device to read SMS.
That’s great, but I can’t get the Osprey to show the texts - the 192.168.1.1 code in a browser doesn’t work regardless of whether I have my device plugged into my computer or if I’m trying to enter it on my phone.
Dr. Caitlyn Mankey BSc DVM MRCVS
Caitlyn the Locum Limited
xxxxx xxxxxxxxxxx xxxxx xx xxx xxx xxxx xxxxx xxxx
xxxxxxxxxxx
xxxxxxxxxxxxxxxx
[Mod edit: please do not post personal information on the forum]
What happens when you click on http://192.168.1.1 from a device connected to the Ospray? What do you 1st see?
It just doesn’t load a page at all, the browser times out.
xxxxxxxxxxx
xxxxxxxxxxxxxxxx
Then the device you are using is not connected to the Ospray by WiFi. Find its SSID in your list of networks seen & supply its WiFi password as found on the label underneath.
