by Trish44
Can you add roaming add-on to the 4GEE Wifi Mini?
If you can how do you apply for add-on roaming to the 4GEE wifi mini, new to EE systems
Solution
Re: Can you add roaming add-on to the 4GEE Wifi Mini?
When you've got abroad & you start wanting data it will direct you to a link where you can buy it.
To phone EE: The local rate landline number 020 7362 0200 or Freephone 0800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & EE TV.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC
Solution
by Trish44
thanks for the response, have you actually done this with the 4GEE wifi mini, as I've tried to apply for roaming facility using the text method and it says it's not possible.
Hi @Trish44
Whilst you are abroad and you try to surf the web you should be automatically be redirected to http://add-on.ee.co.uk/purchase this should then allow you to purchase data.
Many thanks,
Lee
No, there is no text method for acquiring roaming data, just the link you are directed to when you try & use it.
