Highlighted
Can the 4GEE Mini be a wifi hub? Want to stream from iPhone to Google Chromecast
Can the 4GEE Wifi 2 or mini be used as a Wifi hub? i want to stream, between devices that are Wifi connected to it, but not sure this is possible on this device. Would i have to used the Netgear Nighthawk to do this?
6 REPLIES 6
Highlighted
Re: Can the 4GEE Mini be a wifi hub? Want to stream from iPhone to Google Chrome
@Lee_smart   It should work as long as the iOS your using supports  Chromecast not all iOS apps do.
Have a read of THIS
Highlighted
Thanks for replying, but the question was making sure the 4GEE allows streaming between devices. Not sure if traffic between devices that are connected to the 4GEE is blocked and only allowed to go directly out to the Internet. I have it working on my home broadband router
Highlighted
Hi @Lee_smart,
Welcome to the EE Community.
Yes, you'll be able to cast via the 4GEE mini.
Thanks for your question. Smiley Happy
Highlighted
Thanks...will buy and play.
Highlighted
No problem @Lee_smart Smiley Happy
Let us know if you have any other questions.
Highlighted
Make sure the setting for "AP Isolation:" is Disabled.
Recent solutions
