by Camford1995
Can I use 4GEE WIFI abroad?
Solution
Re: Can I use 4GEE WIFI abroad?
Good morning @Camford1995
Welcome back to the community 🙂
Just in addition to the information @XRaySpeX has given to you, it may be worth checking out our DATA USE AND ADD-ONS help and support pages.
If you're going abroad, you'll need to check that roaming is enabled before you go.
For 4GEE devices you can do this in your Connection Manager.
Connect using Buzzard or Kite
Make sure you're connected to the 4G network then:
  1. Go here or type http://192.168.1.1 into your browser's address bar to log into Connection Manager
  2. Once you're logged in to Connection Manager, go to Settings > Dial up  > Mobile connection
Connect using Osprey
Please make sure you're connected to the 4G network then:
  1. Go here or type http://192.168.1.1 into your browser's address bar to go to connection manager
  2. Once you'e logged in to Connection Manager you go to: Connection > Connection Mode
Then you’ll have two options:
  • manual - the device will only connect to the internet when you click the "connect" button on the Connection Status page
  • automatic - the device automatically connects to the internet when the device is switched on
For ease of roaming, ensure that automatic is selected an the box is ticked.
Tablets
For tablets, you can change your roaming settings in your tablet settings.
Anything else you need just please give us a shout and I hope to see you back in community again soon.
Richard
Yes, while paying roaming rates.
Solution
Tablets
Richard
