by Wano69
New Member
Can I put a unlimited data plan Sim card into my iPad
I have an iPad with EE and I was thinking about getting a unlimited data Sim and was wondering if I could put that Sim into the iPad
Solution
Re: Can I put a unlimited data plan Sim card into my iPad
Hi @Wano69
Yes you can.
Solution
Hi @Wano69
Yes you can.
