by bazcad Contributor
Can EE signal box be used with 4GEE home Wi-Fi router
14 REPLIES 14
by Star Contributor
Star Contributor
Re: Can EE signal box be used with 4GEE home Wi-Fi router
I know of others who have got it to work without any issues yes!
Thanks Peter. Do you happen to know if it is possible to register a second hand signal box from eBay ?
EE Community Team
Hi @bazcad,
You wouldn't be able to register a signal box to your account from eBay I'm afraid.
They are linked to a customer's account and can only be registered there.
Alex
Okay thanks Alex.
EE Community Team
@bazcad,
Was there a reason you needed the signal box at home?
Do you have fixed home broadband with EE at home too?
Alex 🙂
Hi Alex, I have just taken out 2 contract on a 4GEE Wi-Fi router and a pay monthly contract sim only. The router picks up a great signal in my windowsill but my phone signal is virtually non existent inside the house. Any ideas on improving this please?
@bazcad.  Does your device support WiFi calling as you could use that.
Hi Chris, it's a HTC One m8. I'm not sure if it does. If it dies Would I still need to  contact EE to get Wi-Fi calling set up?
@bazcad. Unfortunately that device doesn’t support WiFi calling.
If the router gets a good signal but the phone doesn't, why not just connect the phone to the router over WiFi?
Hi Xrayspecs, my phone doesn't have Wi-Fi calling option. I'm looking into buying a new phone
I'm not talking about WiFi Calling but just connecting over ordinary WiFi. That will cover your data requirements but you'll still need to make calls & texts from the phone but they don't usually require such a strong signal.
Hi xrayspecs, I want to leave my mobile phone able to make and receive calls while connected to the 4GEE router when i am at home because i have no mobile signal on my phone unless i am sitting at a particular window sill.
Yes, that's what I'm talking about.
