by Joiner3
Are the lights on
Lights on my wifi mini 2 router are not lit, its working but shouldn't the lights be lit, thx
Solution
Re: Are the lights on
Hi @Joiner3
If fully charged, then yes. The device also goes into sleep mode, so the lights switch off to save battery power.
Solution
Hi @Joiner3
Recent solutions
