by Gees92
Am I able to use my 4GEE wifi box in Mexico using the data already on the device
  • Am I able to use my 4GEE wifi box in Mexico using the data already on the device
Re: Am I able to use my 4GEE wifi box in Mexico using the data already on the de
You can use it but the data you have is only for UK & EU. You will need to buy a roaming data add-on.
Hi @Gees92
As @XRaySpeX mentioned above, your data allowance is UK and EU inclusive.
In order to use it abroad, you would have to make sure the device is set up for roaming through your My EE account and purchase a roaming add-on while you're there.
If you have an EE mobile phone on one of our 4G Max plans, you are able to use your calls, texts and data when roaming in Mexico, Australia, Canada, USA and New Zealand too.
This means that you could use your phone as a hotspot instead of taking your 4G WiFi box.
I hope you have an amazing time. 🙂
