by Nadia14 Investigator
4gee wifi mini
4g EE wifi mini shows red light under the 4g sign. I have checked the network signal in the area and it says there are no problems. I have topped up the sim but it's still not working
7 REPLIES 7
EE Employee
Re: 4gee wifi mini
Hi @Nadia14 and welcome to the community.
What happens when you pop over to http://add-on.ee.co.uk/status ?
Many thanks,
Lee
Re: 4gee wifi mini
When I click on the link it sends me to a page that's 'forbidden' ??
EE Employee
Re: 4gee wifi mini
Hi @Nadia14
Please try popping the device off and back on, does this help?
Many thanks,
Lee
Re: 4gee wifi mini
Yes I have tried that and tried resetting it but it doesn't help 😞
EE Employee
Re: 4gee wifi mini
Hi @Nadia14
You will need to speak to our technical team to have this one looked into.
Many thanks,
Lee
by Peter1965
Re: 4gee wifi mini
I keep having the same problem, I have tried resetting the wifi mini even taken the sim out and reinserting it but still the same problem
Re: 4gee wifi mini
Hi @Peter1965
Have you checked the network status checker too?
This will let you know if there are maintenance works in the area.
You can report a problem and sign up for updates on there too.
Do you have any other devices that are having problems connecting to 4G?
