by sdrawcliffe
4gee wifi mini USA
i have a 4gee wifi mini ee pay as you go with no credit. i would like to know how i top up to use the 4gee wifi mini in the USA before I leave.
11 REPLIES 11
Re: 4gee wifi mini USA
I believe they only work in UK or at most EU.
You may top up at an ATM, using the top up card in a shop or buying a voucher in a shop.
EE Employee
Hi @sdrawcliffe and welcome to the community.
You will be able to use the 4gee wifi mini in the USA, please use the mobile number connected to the sim and top up via an ATM machine.
@XRaySpeX it is only the 4GEE Home routers that have the UK restriction.
Many thanks,
Lee
by sdrawcliffe
lee, thanks for the advice, is there a way of sorting this before leaving the UK, maybe purchase a new sim & package.
thanks.
stuart.
Sorting what? All you need to do is top up. You could buy a new PAYG data SIM if you like.
by sdrawcliffe
i would like to top up prior to leaving the UK and i want to ensure that the top up will work in the USA.
EE Employee
Hi @sdrawcliffe
When you have topped up and you try to use your WIFI mini overseas it will alert you to purchase a bundle compatible with the country you are in.
Many thanks,
Lee
by Profile closed
Not applicable
@Lee_H Are you sure 4GEE mini WiFi dongles will work in the USA?
Last time I checked they only had LTE bands 3 (1800Mhz), 7 (2600Mhz) and 20 (800Mhz)and UMTS bands 1 (2100Mhz), 3 (1800Mhz) and 8 (900Mhz), none of which are used in the USA unfortunately?
EE Employee
Hi @Profile closed
We have had confirmation that previous and current devices will work on the following bands:
LTE Bands supported
3(1800MHz),7 (2600MHz),20 (800MHz)
3G Bands Supported
1 (2100MHz),3 (1800MHz),8 (900MHz)
2G Bands supported
Not supported
Many thanks,
Lee
@Lee_H: How does that square up with @Profile closed saying those bands don't work in US but yet elsewhere you say this device does work in US?
EE Employee
Hi @XRaySpeX
We now have confirmation that the device will only work on the bands I have supplied above.
If USA is on different bands the device will not work.
Sorry about the confusion.
Many thanks,
Lee
by Profile closed
Not applicable
There is no LTE band 3,7 or 20 in the US.  Details here.
(sat using AT&T LTE band 2 as I just landed at Atlanta and we are sat waiting for our gate to be vacated!)
