by GG3 Contributor
4gee mobile wifi booster
Where I am, the mobile phone signal is terrible, so I've got a 4gee mini wifi unit, but only ever get 1 bar on the strength, so often get either very slow or non existent Internet and wifi calling. Are there any legal signal boosters out there. I don't have any broadband, so wifi boosters that use the broadband router are no good to me. It's the actual signal strength that I need boosting.
Re: 4gee mobile wifi booster
@GG3  Sorry but it's not legal to boost any network signal in the U.K.
by GG3 Contributor
Hi Chris
Thanks for the reply. I understand that, but I'm sure I remember seeing something a long time ago, that could amplify the signal indoors, e.g. If you're only getting 1 bar, it would take that and amplify it? Ive tried looking around, but can only seem to find things that refer to using your broadband to amplify the signal.
@GG3   You can get a antenna that redirects the signal it captures.
You have an antenna on your home and it's linked to a box in your home that then gives out that signal indoors.  Your home is not then blocking or interfering with that signal as it's fed directly indoors.
by GG3 Contributor
Ok, thanks for your help. Any idea of any makes/models that will do that. It's hard to know where to look with so many illegal antennas out there.
