close
4gee mini wifi
Merloman
I replaced a osprey2 mobile wifi because it had a swollen battery & I was worried it would catch fire, with 2 off 4 gee mini wifi dongles, the speed is atrocious with 0.5mps or less on both units, the osprey gave 50mps, why is there such a difference, the price per month is the same ?
Leanne_T
Hi there @Merloman
Do we have any signal problems showing for your area on our EE Network Status Checker?
Are you using the same SIM card in both devices?
Speak soon 🙂
Hi Leanne
yes checked coverage it's all ok
have separate SIM cards
done speed check, get between 0.5 & 1.5 mbs on each of them but very slow at starting,
if I connect via iPhone it goes at 45
my wife's a teacher & is supposed to be teaching online from home, it's impossible at the moment unless you connect to the iPhone but then data goes fast, not impressed
John
James_B
Hi @Merloman,
Please get in touch with Customer Care so our Tech Gurus can take a look at this issue for you.
They'll be happy to help.
