Re: 4g wifi password
@quinnw wrote:
They also said its username admin and password admin but couldn't understand why I was only being asked for a password.
Nor can I! There's something peculiar about that screenshot you posted. It is unlike as I would expect. This is the equivalent from an Osprey 2 Mini; I would expect the 4GEE Wifi Mini to be similar.Capture.JPG
Yours has that Yellow block to login to change the SSID & pwd; mine doesn't. It does not fit with the 4GEE WiFi Mini's Set up as a WiFi hotspot instructions which do not refer to that Yellow block. Surely it should?
Does your page have a "User Guide" link at top R? Click on it. What title User Manual does it show. What are the instructions for How to login to the Configuration page . Mine gives:
Where did you get this device from?
by Lucille Investigator
Hi I am having the same problem as you had (same picture as you posted re admin log in). I am trying to log in to admin pages but it does not offer me a space to put USER NAME only PASSWORD and therefore "admin" is not working.  How did you sort your problem please?
Hi there @Lucille
Have you tried the advice such as a factory reset previously provided within this post?
Speak soon,
Katie 🙂
@Lucille : Have you tried following the advice given above to the OP?
Hi thanks for reply. I’ve sorted now as I found out there was a password from when it was installed. L
Glad you got this sorted @Lucille
Come back to the community anytime 🙂
Recent solutions
