Highlighted
by Investigator
4g wifi mini not visible
Hi, I bought a 4g wifi mini a few weeks ago but have had mixed success. It's previously worked, but now my devices don't see it listed as an available network. I've tried:
  • rebooting
  • resetting it with the reset button
  • logging in via a browser to reset (the page won't load)
Currently, the only way to turn it on is to press the button for about 10 seconds. I need to download some software, but the last time I managed to connect to the wifi mini and start the download, it failed.
This is very frustrating as I've got lots of data left, but I can't use it! I'd be really grateful if someone could help. Thanks.
Highlighted
Re: 4g wifi mini not visible
Hi @Wren_nest.
Welcome to the community.
When doing the reset, are you holding the button for ten seconds too?
Where did you get the device from?
Jon
Highlighted
by Investigator
Hi, yes, I'm holding the reset for 10 seconds. I got the device from Argos.
Highlighted
Thanks @Wren_nest.
I'd recommend contacting our Tech Gurus who will be able to look into this further for you.
They will be able to run additional tests.
Jon
Highlighted
by Investigator
thanks @Jon_K . Unfortunately I tried that yesterday, and again just now, using chat, but the service says it cant help me.
Highlighted
Thanks @Wren_nest.
I'd recommend calling if possible.
Our Tech Gurus, who are our advanced technical team, are only available over the phone.
Jon
Recent solutions
