by deanquinlin Investigator
4g mobile broadband signal
i am struggling with signal with this device in our static caravan, am i able to get an antenna installed to improve reception as it only has a usb port?
4GEE WiFi
DIMENSIONS
Size: 65.7 x 96.3 x 18.8mm
Weight: 150g
4GEE WiFi
WHAT'S IN THE BOX?
  • Device
  • Power Cable
  • Battery
  • USB Cable
  • Quick Start Guide
WHATS IN THE BOX?
Battery capacity 4300.0  mAh
Memory internal memory 256.0  MB
Size & Width height 65.7  mm width 96.3  mm depth 18.8  mm weight 150.0  g
Connectivity wi-fi 802.11a/b/g/n/ac
6 REPLIES 6
Re: 4g mobile broadband signal
@deanquinlin : No, it has nowhere to attach an aerial.
EE do sell the 4GEE Home Router which has an optional aerial service but it is only mains powered.
Have you checked the Network Status Checker there & logged the problem?
yes called them and they said an antenna!!!!!!!!!!!!!!!
when you say mains powered do you mean plugged into the mains or do you mean aerial connection , as the router is already mains powered and doesn't have to be mobile use as i am happy for it to stay static.
Hi @deanquinlin
With this router you would be able fix an antenna.
https://shop.ee.co.uk/dongles/pay-monthly-mobile-broadband/4gee-router/details
It's mains powered, not mobile like the yellow one. If you have a static site caravan, then this maybe a better option than the yellow one.
I meant the 4GEE Home Router is itself mains powered. It has no internal battery like the one you've got.
THANKS.  Would this need a phone line ?
No, it's just like yours in that it gets its signal over the mobile network.
