by xbell88 Investigator
4GEE wifi mini - apparently full strength signal, but no connection?
Hello there!
I have come home tonight to find that, while apparently having a very strong signal strength and no issues in the N21 1QR area I cannot connect to the internet.
I had 24GB of data this morning, everything qas logged off, so I doubt it has been eaten away. I have tried resetting, moving it around the room, but nothing has worked!
I can connect to the EE management site, but that's it.
What else can I do?
Edit: ran troubleshooter and it says I need to sign up with the ISP?
10 REPLIES 10
Re: 4GEE wifi mini - apparently full strength signal, but no connection?
Good evening @xbell88
When did you last use the device?
Do any lights show at all?
Hope to hear from you soon 🙂
Last used this morning, where it appeared fine.
I get 4 proudly flashing green lights, and a nice blue 3G light.
https://ibb.co/nGxQ0k
https://ibb.co/jHs3mQ
I took photos of the lights and status page.
Great thanks @xbell88
Do you have any other EE devices in the house having problems?
If not I would suggest restoring the device settings and if required performing a master rest.
All information can be found here 4GEE - WiFi Mini Help and Support
Let me know how you get on 🙂
It is my only EE device.
The restore and reset do not seem to hve done anything other than revert the password and login details to default. I still have 4 bars, but no connection.
It has been reset/restored twice now (once before posting, and just now). The little yellow triangle is still mocking me 😉
Hi @xbell88
According to the EE network status checker there is an issue in your local area:
WE'RE HAVING A LOOK AT N21 1QR
We're investigating a recently reported problem. Click below and we'll update you when there's news.
You can keep an eye on the status here.
There is, because I just reported the connection issue 😊
I figured if nothing was working I should report it and see if it is just me having issues. I can conect to my GiffGaff hotspot no problem, it is just EE.
@xbell88
Brilliant,  at least EE problem reporting system works! Smiley Very Happy
Hope it gets sorted for you.
Hi @xbell88,
You've done the right thing in reporting the issue.
You should be updated once the issue has been investigated.
It's also worth getting in touch with customer services and having a chat with our technical team, to rule out a problem with the device itself.
@Northerner @Leanne_T @James_B
I have spokent to the technical team, and the lovely John has informed me the security team are doing a check on my account so it has been restricted.
So I'm off to an EE shop as soon as possible, to hopefully fast forward the checks!
Thanks everyone 🙂
No problem @xbell88 Smiley Happy
Thanks for letting us know.
- James
