30-06-2020 07:32 PM
Any suggestions Folks?
Just upgraded from mini wifi to larger one...
Got it all swapped over ok and connection keeps dropping out..
Done signal check.. rebooted etc.. showing 3 or 4 bars so should be good but still drops out??
03-07-2020 05:43 PM
All good so far so going to say
The solution is; after upgrading from a mini to full size unit once SIM has changed over press master rest for 20 secs, then all should be good !
Thanks for help
30-06-2020 11:39 PM
Just to add, the connection only holds for a matter of minutes...
As it stands its not fit for purpose, and desperately needs resolving as this is my sole means of internet
Please can a tec guru advise asap
01-07-2020 08:22 AM
Hi @Wildextreme.
Welcome to the community.
Are you using the same SIM card that you used with the old device?
Are you able to perform a pin reset on the 4G WiFi device?
Jon
01-07-2020 09:23 AM
Hi Jon, thanks for reply
New sim came with device, done the sim changeover as per instructions.
Will try master reset button using a pin
01-07-2020 09:30 AM
01-07-2020 10:34 AM
Hi Jon,
Just done master reset Using the button on device
So Far (15mins) not dropped out, ive quite a bit to do today on line so will monitor to see how it performs
So im going to leave this ticket open - but will update when 100% confident the issuse is ressovled
Many thanks for your speedy reply
01-07-2020 10:57 AM
03-07-2020 05:43 PM
Thanks for help
04-07-2020 10:07 AM
