by Engelsepiet Valued Contributor
Valued Contributor
4GEE router drops connection
Seems to lose connection overnight. I have to power down and then restart.
6 REPLIES 6
Re: 4GEE router drops connection
Which router model?
Valued Contributor
@XRaySpeX wrote:
Which router model?
Just has Model: 4GEE router
Tiny text below that is:
HH&OV8 (last character could be a B
Can you post a photo? Where you buy it?
Valued Contributor
Bought from EE shop
EE Employee
Hi @Engelsepiet and welcome to the community.
Could I get you to try a factory reset to see if that helps?
Many thanks,
Lee
Valued Contributor
Hi, Lee,
Will do. When I took those photos this morning, Murphy's Law meant that it was the first time that the router had not dropped out overnight!
