by bodycombateer
4GEE not working
if i plug it into usb port, power button lights up as if charging but when i turn it on, all the lights come on but nothing seems to happen and it's not being discovered by laptop and tablet.
Tried pressing reset button but does nothing and can't access via cable
Re: 4GEE not working
Hi @bodycombateer
If the reset button doesn't reset your device, then you will need to take your device into EE to send off for repair.
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover & check its Connection Status.
