by Milkshake1 Investigator
4GEE mini wifi lights
EE light pulses fine. Connection to internet fine. Blue strength indicator/yellow battery life not visible. Touch power button for a nano second lights appear then after 10 seconds dissapear.
This cannot be right?
Please advise.
Thnak you
by Legend
Legend
Solution
Re: 4GEE mini wifi lights
No that's exactly what should happen. The only indication it's on is the flashing EE logo.
by Legend
Legend
Solution
Hi @Milkshake1 and welcome to the community.
@Northerner is indeed correct.
Many thanks,
Lee
Thank you for your quick and helpful reply.
Kind Regards
Lee
Thank you you guys for your quick and helpful reply that has solved my query.
Kind Regards
Lee
