by Robster1
4GEE home broadband - where can I get the two antennas to plug in to the back?
Hi Guys
I just recieved the 4GEE home broadband - 200GB per month, which is working really well.  I want to get the two ariels/antennas that plug into the back of it.  I don't want the external/outside the house ariels, just the two small antennas that fit directly into the back.  Any ideas?
Re: 4GEE home broadband - where can I get the two antennas to plug in to the bac
Hi @Robster1
Welcome to the community 🙂
Have you spoken to our customer service team about this?
They will be able to tell you what antennas are available from EE directly.
Jon​​​​​​​
by Robster1
Hi Jon
Thanks.  I've spoken to EE and they can only provide the external antennas to go on the side of your house - they don't provide the ones that fit onto the box.
by DrBigB Established Contributor
Antennas can be purchased cheaply on the internet.  I purchaed these on Amanzon
https://www.amazon.co.uk/gp/product/B07477FPKC/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
 When I connceted them I did not see any improvement in performance, but it may have been becauseI live in an area with a very good 4G signal.
The link will show the connection you need to fit the sockets on the EE router if you decide to try an aternative brand.
