Highlighted
New Member
4GEE WiFi
Why is EE 4G so expensive and limited in the amount of data?
The largest data pack EE offer is 50Gb which is c£33 for 24 months. in comparison, BT are advertising 100Gb for £35, 200Gb for £40 etc. all the way up to £60 for unlimited data.
Highlighted
by Ace Contributor
Solution
Re: 4GEE WiFi
Hi @Reb2,
You can put an EE unlimited phone SIM in the portable WiFis if you want. The data only SIMs are priced higher than phone SIMs for a variety of reasons, primarily the user consumption profile.
Thanks,
Peter
Highlighted
by Ace Contributor
Solution
Re: 4GEE WiFi
Hi @Reb2,
Thanks,
Peter
Recent solutions
