by Bushbaby7 Investigator
4GEE WiFi Mini
My new 4GEE WiFi Mini takes 4 hours to charge then only lasts about 6 hours.  Could this be a faulty battery?  Should I take it back to Curry's where I bought the unit?  Appreciate any advice.  Thanks.
7 REPLIES 7
by Profile closed
Not applicable
Re: 4GEE WiFi Mini
Hello @Bushbaby7 mine takes around the same to charge from flat to full (around 4-6hrs) and depending on how heavy my usage is at the time I can get anything from 3-12hrs out of a full charge. 🙂
Re: 4GEE WiFi Mini
Thanks Tom222.
by Profile closed
Not applicable
Re: 4GEE WiFi Mini
You are welcome @Bushbaby7. 🙂
Re: 4GEE WiFi Mini
Hi @Bushbaby7,
Welcome to the EE Community.
I see @Profile closed has already given you a great answer to your question.
Don't hesitate to let us know if there's anything else we can help you with.
Thanks Smiley Happy
Re: 4GEE WiFi Mini
Thanks James B. This is my third attempt to reply.
I'm quite disappointed with 4GEE WiFi Mini given the fact that I'm hardly
online and when I need to work on my laptop, 4GEE WiFi Mini is depleted and
needs charging again, forcing me to use my mobile data through another
service provider. I'm paying £22 a month with EE but not using it's
service which is very frustrating.
Are there other EE products which would provide longer usage hours please,
as 4GEE WiFi Mini doesn't work for me?
by Profile closed
Not applicable
Re: 4GEE WiFi Mini
Hello @Bushbaby7 you can keep it on charge when using it and it should stay on just keep it cool and unplug it if/when it starts getting hot to avoid any premature wear to the battery.
The standard 4GEE WiFi has a notably longer battery life:
https://shop.ee.co.uk/dongles/pay-monthly-mobile-broadband/4gee-wifi/details
They are the only two battery operated MBB devices available direct from EE. 🙂
Re: 4GEE WiFi Mini
Hi @Bushbaby7,
Are you turning the device off when not in use?
This will conserve battery life for when you need it.
