by geoffers12 Investigator
4GEE Router HH70VB - firmware issue/bug
I've looked for an updated firmware - but can't find one.
Lan IP
10.1.1.1
Netmask
255.255.0.0
If I set the dhcp range to
10.1.1.100 to 10.1.1.200 it sets fine and works
10.2.1.101 to 10.2.1.201 [which is valid on this subnet mask]
it accepts it [and saves] but on the screen refresh it shows and uses 10.1.1.101 to 10.1.1.201 !
So the firmware is obviously ignoring the subnet mask and assuming that the dhcp range has the first 3 parts of the ip address the same as the lan ip of the unit.
[I'm not actually going to be using 255.255.0.0 but it's an easier example to show it not working as it should]
Re: 4GEE Router HH70VB - firmware issue/bug
They’re in an overlay file system so worst case scenario a factory reset will remove the changes and revert to rom versions.
Granted not something we suggest every tom **bleep** and Harry start doing - especially when restricted to using vi, but it must be allowed otherwise it would be blocked Smiley Wink just like changing the subnet mask lol
Nothing as complex or warranty voiding.
ssh
As far as I know EE has never provided a download repository for firmware updates. If it decides to do updates it will force-feed them.
To phone EE: The local rate landline number 020 7362 0200 or Freephone 0800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & EE TV.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC
I've done some more investigation work.
The web config portal sets the start and limit options in /etc/config/dhcp
and only sets the last digit of the ip range -> which is why it's ignoring the netmask
it uses /etc/config/dhcp to generate the /tmp/etc/dnsmasq.conf file
This shows the full ip but uses the routers first three octals and the start+limit options to fill in the rest.
If I manually edit the /etc/config/dhcp file and change the start option manually to have the full ip showing instead of just the last digit [on a reboot] it generates a new /tmp/etc/config/dnsmasq.conf file with the correct settings
I'll investigate more
Hi @geoffers12 and welcome to the community.
Let us know how you get on.
Many thanks,
Lee
What is this "web config portal"? You mean the firmware code in the router, which you are hacking manually? Good luck!
The web interface that the router gives for you to alter its settings
I’ve not mentioned altering the firmware - just manually editing the config files (which normally is left to the web interface to do)
This isn’t a mobile phone or tablet but a standalone router with its own web server for config changes
Sorry, I didn't really mean firmware but manually altering the files held by the OS (the firmware) of the router, which are not normally accessible to the user thro' the admin web interface.
I guess you've made an RS232 connection to the router.
OK. Just out of interest how do to get into the OS from the menu/form driven web interface to invoke ssh?
It’s enabled by default - supprised me aswell
