Highlighted
4GEE Hub speed gone from 5MBps to 1MBps after restart
I recently turned off my 4GEE hub by accidentely unplugging the device, I turned it back on and it worked as usual, however when I went to download something I noticed the speed had dropped dramatically. Does anyone know why this is the case?
Highlighted
Re: 4GEE Hub speed gone from 5MBps to 1MBps after restart
Hi @DeclanFarrow,
Restarting your router wouldn't affect your download speeds.
It could just be that the server you were downloading from was busier than usual.
Highlighted
I have tested on multiple servers and multiple devices, can assure you its not the server.
