by CANDEM
4G Mobile Wifi Mini 2 Security
Hi - I'm looking to buy a Wifi Mini 2 to connect D-Link devices.  Can anbody tell me if the Wifi Mini 2 can be configured to use WEP security protocol.
by Star Contributor
Star Contributor
Solution
Re: 4G Mobile Wifi Mini 2 Security
The 4GEE WiFis support WEP for WiFi encryption, which can be found in Settings->WiFi->Basic->Security.
I wouldn't recommend WEP though!
by Star Contributor
Star Contributor
Solution
by CANDEM
Thanks - unfortunately some DLink items you don't have the option of not using WEP
