by Alan12
4G Home Broadband Router "Green Light" flashing
Hi I have purchased the 4G EE Router and when first connected had the intermitent blue flashing light identyfiying as a 4G signal and everthing worked fine, but the next day when the router was unpluged overnight and then plugged back in the same location the next day the blue light is now flashing "green" but unable to connect any devices to the router.
Re: 4G Home Broadband Router "Green Light" flashing
Hi @Alan12
Welcome to the community.
Do you have any other EE devices that have a 4G signal?
Please also check the status of the network in your area on our status checker.
by Alan12
Hi Chris
solved
it was a new account and EE blocked the SIM after one day due to an internal account mix up
all working ok now
Alan
Glad it's sorted, @Alan12.
Thanks for letting us know. 🙂
