by jonic81
New Member
Trigger Issues
I have had my action cam since January and have used it once - I went to use it the second time and the yellow trigger button doesn't seem to be working - it's not recording or taking photographs. I don't have insurance - is it covered on warranty??
by Brilliant Contributor
Re: Trigger Issues
Hi @jonic81 Yes it should be covered by warranty you will need to contact EE to arrange a repair
Re: Trigger Issues
If there is.  an EE store near you, you can take it in there, and they will change it for you. This happened to me, no problems changing it.
Re: Trigger Issues
@Schockwave that's good to know I thought they would have to send it away
Re: Trigger Issues
Well, this was a year ago, and I went into EE store and they just exchanged it for a new one, cannot say whether this would work with everyone, but at least it is worth a try.
