by sarahchadwick Investigator
Capture Cam Battery
Just want to check if my capture cam is faulty or not; the battery on a full charge is lasting about half an hour when recording and roughly about one hour just in use.Is this right?
EE Employee
Re: Capture Cam Battery
Hi @sarahchadwick and welcome to the community.
That does sound a little peculiar.
Please, can I get you to master reset the cam and see if that helps Smiley Happy
Let us know how you get on.
Many thanks,
Lee
Thanks for responding.What is a master reset please.Also is it possible to open the camera?
@sarahchadwick  Here’s the capture cam manual >CLICK HERE< and I don’t think you can open it.
Thank you. Shame you can't get the batteries out of these things. It's the only thing letting them really down.
