by kavagle
New Member
zero data usage then too much
For the first time ever I received a text to tell me I had nearly used all my data.   When I looked up my data usage for this month I have 1.7Gb left out of 10Gb, this resets on the 20th of each month.  I never use this much and wonder if something has gone wrong
However, last month it states I ony used 2 Mb and the 2 months prior I used zero!  Is there some way of checking if this is correct or not?
by Ace Contributor
Re: zero data usage then too much
@kavagle
Click on this link http://add-on.ee.co.uk
On your mobile data Internet not wifi and check what response you get here.
Many Thanks
Hello there @kavagle
Welcome to the community
What device are you using?
Have you recently changed the device or downloaded any new apps?
Thanks 🙂
