by nottsannie
xperia x cannot get mobile data
i have a xperia x and my mobile data isnt working, i checked coverage and thats fine, i have turned airplane mode on and off and also reset my network settings and still nothing can anybody help??
6 REPLIES 6
Re: xperia x cannot get mobile data
Hello there @nottsannie
Is this now working for you?
Let me know how you are getting on 🙂
by nottsannie
yes this is working now thank you
Great news @nottsannie.
Thanks for letting me know!
Have a great day 🙂
by yishun0858
Mine still don't work though. And I noticed that if I switch the APN protocol into just IPv4(the default setting is IPv6/IPv4), everything works fine. So is it there's some problem of the IPv6 protocol in EE, I have experienced this issue since yesterday.
EE Employee
Hi @yishun0858
I am not quite sure on what was the cause of the issue, but if you are still experiencing a problem do get in touch with Customer Services.
Many thanks,
Lee
