by ANDREWMAY
will your nano sim work in a very old car phone- a nokkia 3110
Will a nano Sim from a smartphone work in a very old Nokkia 3110 (with an adapter). My current providers Sim doesn't although an o2 Sim I tried did
Solution
Re: will your nano sim work in a very old car phone- a nokkia 3110
Probably not as EE only use the 1800MHz on 2G. You can always try.
@ANDREWMAY   Depending if the device is locked to a network will depend whether a network Sim card will work in that device, if the device is locked to Orange or T-Mobile and then a EE sim card will not work in it and you need to get the device unlocked to use an EE Sim card that device,  that  was never on EE so it's not going to work with a EE SIM card until it's unlocked.   And if the device wasn't on O2 a O2 SIM card will not work in it.
Is the device unlocked to use any network SIM card in it ?
by ANDREWMAY
It was never locked and has worked on both vodafone with an old technology standard size sim and on o2 with a nano sim from a smartphone (with an adaptor)It will not work with a vodafone nano sim from my smartphone.
Sent from my Samsung device
Solution
