by TOPPERK Investigator
wifi connected - no internet connection EVEN WITH DATA
HI MY NEW PHONE GETS NO INTERNET WIRELESS OR WITH DATA ?? ANY HELP WELCOMED
Solution
Re: APPLE 8 PLUS
@TOPPERK    Ok I’ll help you get this sorted.
Open settings on the device.
Click WiFi and find your WiFi router name and click it.  You’ll need to enter your WiFi password to get WiFi access.
39 REPLIES 39
IS THERE NO HELP FROM TECH AT EE??
LOOKING FOR HELP WITH IPHONE 8 CANT GET INTERNET NO MATTER WHAT I DO HELP WELCOMED OR THEY CAN FOXTROT OSCAR WITH PHONE ITS NOT EVEN A WEEK OLD YET
APPLE 8 PLUS
NO INTERNET NO MATTER IF WIRELESS OR DATA ??? CAN ANYONE HELP !!!!!! NEWBIE
Re: wifi connected - no internet connection EVEN WITH DATA
@TOPPERK: If you are connected to WiFi you won't be using mobile data nor even EE. If you can't get the Net over WiFi that's an issue with the WiFi. What WiFi you trying to use?
ITS VIRGIN WIFI IM GETTING 60 MEG ON PC NOTHING ON PHONE THEN SWITCH TO DATA THAT GETS NOTHING EITHER
Re: IS THERE NO HELP FROM TECH AT EE??
@TOPPERK  Is cellular data enabled? Have you allowed the apps to use cellular data ?  Is Wi-Fi enabled ? Have you put your WiFi password on the device?
Solution
Re: APPLE 8 PLUS
YES TO ALL ABOVE , I HOPE NOT SIGN OF FUTURE ALL FINE TILL YESTERDAY
Re: APPLE 8 PLUS
ITS BEEN FINE UNTIL YESTERDAY NOW NADA EVEN DONE FORGET AND REDONE NOTHING
@TOPPERK   Go to Settings>General>Reset>Reset Network Setting.    The device will shut doesn’t then restart on its own.   You’ll need to put your WiFi password back on the device after this.
Re: APPLE 8 PLUS
There's no need to shout. It's rude and against Community rules. So is swearing. Did you read them before posting?
Re: APPLE 8 PLUS
ARE YOU FOR REAL WHERE DO I SWEAR AND HOW DO YOU SHOUT TYPING IM 50 YRS OLD BUD JUST TRYING TO GET HELP NOT ARGUE DONT REPLY THEN PC BRIGADE
Re: APPLE 8 PLUS
@TOPPERK   THIS IS SHOUTING
this is not shouting.
And can can you please do what I’ve asked you to do.
Re: APPLE 8 PLUS
THINK YOU WILL FIND I WROTE IN PHONETIC YOU ARE JOKING EH??
Re: APPLE 8 PLUS
JESUS  are you being serious ?? can you please tell me if i get help from ee on weekdays then please
Re: APPLE 8 PLUS
All in CAPITALS is shouting. You have a Shift key; use it.
Re: APPLE 8 PLUS
@TOPPERK  I’m trying to help you if you’ll like that help then please read THIS first.
I’ll help you if you want that help.
as i said bud ive done all that forget then re join etc
@TOPPERK   I’ve not asked you to forget any Wi-Fi password I’ve asked you to go to settings/General/reset/reset network settings on the device.
Re: APPLE 8 PLUS
can you imagine that knowledge is power if you dont do it then you wont get knowledge i dont spend my life glued online and i realy wasnt looking to argue i was only asking for help im old for this and didnt know that caps lock is shouting imagine a human getting it wrong i might grow up to be like you one day good evening sir have a nice
