by robertcurran Investigator
why does my htc10 not work on 4g+
Hi there.
When im out and about in london, when my phone is showing im in a 4G+ zone, im unable to access the internet. It only seems to work when im back in a regular 4G zone. Why is this? Areas such as London Waterloo station i cant check my faceook for example as it says i have no internet even though im showing full 4G+ signal. This affects other apps and also browsing on the internet.
7 REPLIES 7
Re: why does my htc10 not work on 4g+
Good evening @robertcurran
Welcome to community 🙂
Are you having the same problems in a particular area of London?
Or is it multiple locations?
Richard
Richard,
It happens in many areas of London. In particular around waterloo station.
But even at home in Putney when it does go to 4G+ I cant do anything.
And I've had it across town in other areas as well.
Rob
EE Employee
Hello @robertcurran
How long have you been experiencing this issue?
When in an area where you would normally experience the issue can you try doing a manual network search, to see if this then allows you to connect to data?
If you re-boot your phone whilst having the issue does that help?
Thanks - Karen. Smiley Happy
Karen,
Ive had this phone since August last year and its been going on since then.
Its only when the symbol changes from H or 4G to 4G+ that it does this.
As soon as it displays 4G+ it doesnt let anything happen even though its showing the two arrows for data incoming and outgoing.
I'll try the manual search and get back to you. And then re-boot if that doesnt help.
Maybe its a network setting? I bought this phone outright and direct from HTC.
Cheers,
Rob.
Hi @robertcurran,
It doesn't sound like a problem with your network settings.
Please let us know if @Karen_C's suggestion works.
Thanks Smiley Happy
This hasnt fixed the problem at all.
Hello there @robertcurran.
Thanks for coming back to us.
Have you spoken to our technical support team for this?
I would certainly suggest giving them a call to get this looked into.
Thanks.
