by Spurs144 Investigator
when i go from wifi to 4G my 4G doesn't work and i have 4.3 gb left
when i go from wifi to 4G my 4G doesn't work and i have 4.3 gb left please tell me why this is
21 REPLIES 21
by Ace Contributor
Re: when i go from wifi to 4G my 4G doesn't work and i have 4.3 gb left
Hello,
@Spurs144 Please sure your phone data on in your phone settings . is that just on one please or every where?
what is make and model of your phone?
the phone is an iphoe 6s
i dont understand the first question
*iphone 6s
@tahirmian ^^^^^^
by Ace Contributor
Hello,
@Spurs144 have your try with Reset network settings ?, That might help you sort this out.
Many Thanks
@tahirmian I will do that now I will reply once completed
When I switch to 4G it's not working and I have 4.3 GB left please help
Re: When I switch to 4G it's not working and I have 4.3 GB left please help
@Spurs144  Is cellular data turned on ? Have you allowed the apps to use cellular data ?
Yes it is on @Chris_B
@Chris_B still not working
Hi @Spurs144
If you have reset your network settings, made sure data is active and are 100% sure you have data on your account then either your network mast is down or your phone has a problem. You can check your local mast for issues on EE checker.
Try recovery via itunes.
Thanks,
Good Morning @Spurs144
Is this now working for you?
If not do any problems show in your area as @Northerner has suggested?
Hope to hear back from you soon 🙂
@Leanne_T No still not working
Hi @Spurs144
Thanks for coming back to me.
Can you tap the below link with WiFi turned off and let me know what data shows for you?
http://add-on.ee.co.uk/
Also does this happen in all areas?
Thanks, Leanne 🙂
It says I got 4.3 gb left @Leanne_T
EE Employee
Hi @Spurs144
It should allow you to connect as it has connected to the add on page, what error message do you get when trying to connect to other sites?
Many thanks,
Lee
It said Safari could not open the page because the server stopped responding
EE Employee
Hi @Spurs144
I would recommend backing up your phone and restoring to new and see if that allows you to connect.
Rule out any bugs in your device.
Many thanks,
Lee
