by chrcoluk1 Valued Contributor
Valued Contributor
volte not working
So I can enable LTE mode on my phone which is a EE supplied samsung S7.
I get the volte symbol at the top of the screen.
But If I get an inbound call or make a call, it drops down to 3G.
Any ideas what causes this problem, if on an outbound call it takes about 10 seconds as well to drop, so I just get a pause before it drops down to 3G.
It will then stay on 3G for a while after the call giving me slower internet before eventually moving back to LTE.
9 REPLIES 9
EE Employee
Re: volte not working
Hello @chrcoluk1
Welcome to the EE Community! Smiley Happy
How long have you been experiencing the issue for?
Does this happen everywhere you go or is it in a particular location.
Thanks - Karen. Smiley Happy
Valued Contributor
I think it happens everywhere, I can test later today as I am going out to a hospital, I spend a lot of time at home due to my health.
I have discovered something after playing around with my phone.
If I have very recently switched to LTE e.g. going to 3G and then back to LTE, then making a call works over LTE, however if its been in LTE for a while (I dont know exact amount of time), then it has to drop back to 3G for the call to work.
EE Employee
Hi @chrcoluk1
Just a quick question, does your WiFi Calling work ok?
A customer having a similar issue with volte not working found out wifi calling was turned off at account level.
Soon as it was activated volte started working.
Many thanks,
Lee
Valued Contributor
I will test but cannot test now as my home broadband is down, I will test when its back online.
EE Employee
Do let us know how you get on @chrcoluk1
Many thanks,
Lee
Valued Contributor
I will ring to check if I have wifi calling enabled soon, but another update.
I did a call just now that went over volte, but it cutoff after about a minute and my phone had dropped to 3g, then redid the call on 3g and was fine.
Thanks for the update @chrcoluk1
Valued Contributor
wifi calling is active on my account, on EE's advice I will be testing it with the sim in my S5 to see if the same problems occur.  They are also considering sending me a new sim.
Thanks again @chrcoluk1 Smiley Happy
Let us know how you get on.
