by sheldon
New Member
usage data not available on my EE
When i try to check my usage it just says no info and that there are technical dificulties.
What technical dificulties?
I need to know if i am near my limit
What happens if i go over my limit without being given the ability to know if it has happened?
by Profile closed
Not applicable
Re: usage data not available on my EE
Hello @sheldon sorry to hear you are having trouble checking your data. Try restarting your phone and then texting the code AL to 150. You can also check your data allowances using this link from your phones data (not WiFi) connection. :):
http://add-on.ee.co.uk
Text AL to 150 to see your remaining allowances.
You can't go over your data allowance w/out being offered to buy more. Over your calls & texts allowances you start paying standard rates for them
by ukperson Established Contributor
@sheldon
you get a 80% warning text and once you used your data up you get cut off and redirected to the buy more data page (you really should use your phones Built in data monitor, set it to your data start date and set warning and limits below your monthly allowance)
unless you have a iPhone then you need to stupidly buy DataMan Pro or Next to monitor your data monthly (iphone has a data usage page but you have to manuly reset it each month)
Or you could download any free version of any data usage app until you find one you like.   Then if you wish you could purchase full version.   It's best to try before you buy.
Recent solutions
