by ginteri Investigator
some apps don't allow mobile data usage
why some apps such as facebook, Instagram, Snapchat do not allow usage of mobile data?
If connected to WiFi they work.
I have tried Phone/Network reset, and all suggested solution.
I have tried to go in Settings Mobile data and enabled data for these applications, but when I start using the application I am told there is no Internet connection,
Going back in settings they are all disabled again.
I have enabled Full Access on ee account.
Anyone can help please?
Solution
Re: some apps don't allow mobile data usage
Hi @ginteri
Thanks for coming back to me.
Have you tried deleting the app and reinstalling?
Also, have they worked previously on the iPhone?
11 REPLIES 11
@ginteri : Could it be your Switching Content Lock OFF or ON ? It is switched on on new contracts & seems to affect social sites.
Thanks @ XRaySpeX.
I had already checked that  and
Data Content Controls is set to Full Access.
Morning @ginteri
What phone are you using?
Can you access any apps at all?
Hi Leanne. Thanks.
It’s iPhone 6s
yes most apps can be accessed regularly.
only Instagram, Snapchat, Facebook and gmail don’t work unless connected to WiFi internet.
When mobile data gets enabled for those apps it shows as on and as soon as app is used it says “no internet” and it reverts all mobile data back to off for those apps.
Solution
Hi @ginteri
Yes Leanne.
Some apps have worked after reinstalling. But not all 😐
They all worked in the past.
Hi there @ginteri
Is your software up to date on the iPhone?
If so, and other apps are working you may need to try a factory reset on your iPhone, full help and advice is shown below;
How to restore your iPhone, iPad, or iPod to factory settings>
Make sure to back up your iPhone as a reset will delete all information.
Thanks.
If all fails I will have to try this.
Will let you know when I am able to do it.
No problem @ginteri
Let me know how you get on 🙂
Deleting and reinstalling the apps worked.
Great news @ginteri
Thanks for coming back and letting me know 🙂
Have a great weekend.
