by erocute Contributor
slow
Why is the uks fastest mobile network this slow? I'm from Herne bay in Kent and getting 9mb down. This needs to get better. I own a Nintendo switch.
Re: slow
@erocute   Network speeds can vary depending on different factors like how many people connected to the same mast, the weather can effect signal is there a mast down in your area.  Is your home interfering with the signal.
this is my network speeds whilst in my home.
Re: slow
Wow. I envy those speeds. That's just completely not fair. I just did another speed test and got 4mb down and 0.30 up. Crying inside.
EE Employee
Re: slow
Hi @erocute
Please see your other post as we have replied there in regards to speeds.
Many thanks,
Lee
Re: slow
Hi. I've not tried outside yet but tbh I will mostly use it inside. I wish I had speeds 8 times faster like the user above.
EE Employee
Re: slow
