by lukerobinson Contributor
problems with tmobile
i am trying to buy the 1 GB 30 day data add on. when i text 1 GB to 441 i get no response.
i then tried to check my balance to see if £7.50 was taken but i got no response from 150.
by Ace Contributor
Re: problems with tmobile
Hi @lukerobinson
This is an issue which has been widely reported this morning throughout the Community.
I have notified the EE team are investigating this as we speak.
by Profile closed
Not applicable
EE / T-Mobile / Orange seem to be having a number of issues this weekend as there are lots of services not working at the minute.
i will try to buy the addon again tommorrow
EE Employee
Hi All,
You should now be able to contact customer services or use the self service,
We did experience a technical issue impacting our ability to assist customers, we have fixed this and apologise for any inconvenience caused.
Many thanks,
Lee
