by lukerobinson Contributor
orange data not working
i am on orange dolphin plan and i have topped up ten pound.
when i text bundles to 150 it shows a 1gb data reward but i cannot connect to the internet, it redirects to the out of credit page.
how do i fix this problem.
10 REPLIES 10
by Ace Contributor
Re: orange data not working
Have you been migrated to EE ?
no, i am still using orange, i do not want to move to ee
by Ace Contributor
Everyone is in the process of being to moved to EE pay as you go Orange pay as you go is being closed down.
by Ace Contributor
is that why my internet is not working
by Ace Contributor
Text number to 150 it should say if your on a Orange or EE plan
by Ace Contributor
Try restarting your phone.
it says i am on an orange plan, i have restarted my phone and even tried the sim in another phone.
by Ace Contributor
Ring 0800 956 6000 opt 2 opt 4 from 8AM and it will get you through to someone for free.
Hi @lukerobinson
Do you know if there are any maintenance works in your area? You can check our network status checker.
